YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Sign in using an external account
Register Forgot Password?
Search
Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 10-15-2006, 06:43 PM   #1 (permalink)
Personal Sales Rating: (0)
4runnermt's Avatar
miller 375 x-treme plasma cutter
Hey guys, I just ordered a miller 375 x-treme plasma cutter. Has anybody used one of these? If so, I'm curious what you think of this unit.
4runnermt is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 10-16-2006, 02:20 PM   #2 (permalink)
NCSU-4runner's Avatar
Send a message via AIM to NCSU-4runner
thou shalt not covet thy neighbors plasma cutter
i dunno anything about the one you are getting but i've used a very small plasma cutter before and even it was a nice tool to have
__________________
Jeremy,
94 4Runner Turbo
Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap
My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum
One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first.
NCSU-4runner is offline
Old 10-16-2006, 03:32 PM   #3 (permalink)
HarrisonP's Avatar
My dad has the Miller 625 at the house. I use it all the time and have to say that it is so much nicer than having to use a cutting wheel or torch. They do take some getting used to in order to make some nice cuts.
__________________
"Live and learn, Die and forget it all"
1996 4Runner SR5 V6 4x4
Lifted, Locked, and Armored
HarrisonP is offline
Old 10-19-2006, 02:20 PM   #4 (permalink)
Send a message via AIM to yellowspeedracer
That's the one I have. It's great for me but I don't have anything else to compare it to besides a gas-axe.
I got one of these to knock off the slag.
Click the image to open in full size.
__________________
Brandon.
02 Tacoma
yellowspeedracer is offline
Old 02-08-2010, 03:39 AM   #5 (permalink)
glenyoshida's Avatar
Quote:
Originally Posted by glenyoshida View Post
Plasma cutter - expensive as heck and you still have to grind/clean up the edges with a grinder for a clean weld. Even if you could afford it there are plenty of other tools that you would get much more use from. I have one and rarely use it.
Acetylene cutting torch - crude cuts and again you have to clean up your edges with a grinder. It's very time consuming grinding the edges until they are clean and true.
Quote:
Originally Posted by wyoming9 View Post
If you are getting poor cut quality from your Plasma and Oxy- Acetylene you are not doing it correct or need more practice .
If you did it all the time you would be able to get ready to weld pieces from both processes
Hiya Wyoming9, I'd rather be wrong and learn something than proud and ignorant. My Miller 375 x-treme plasma cutter only has two adjustments. The amperage dial and the on off switch. The air flow is regulated at 90 psi by the plasma cutter. I have an air/moisture filter to prevent water although the lines are normally dry anyhow. What exactly are you doing to make for a cleaner cut without contaminates? Are you using nitrogen something? Plasma is definitely cleaner than acetylene but it a long cry from a clean cut that an angle grinder with a cut off wheel will provide. When I cut A36 with my plasma I get cuts that are almost good enough to weld but there is still quite a bit of junk from the cut edge. Are you using MIG or TIG on your welds?
__________________
- Glen -
2001 4Runner Auto - Armorology Bumper - Stainless rear bumper - Warn M8000 w/Wireless remote, 1/2" Technora line - Toytec coilovers - OME 851s w/Bilstein 5100s - Yokohama Geolander MT+ 305/70R16 - Stubbs HD-SKO Sliders - Engel 15 Freezer - Toytec Rear LCA skids - Budbuilt front & belly - Low profile cargo -Viper 5900 remote start - Cobra 18WSXTII CB - VSC disable switch - 2nd Battery - inverter - Interior CO2 ports - Nitro 4.88s - ARB Air Lockers F&R Photos
glenyoshida is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
375, 625, cutter, cutters, date, extreme, forums, manual, manufacturer, miller, plasma, refurbished, sale, treme, xtreme
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Plasma Cutter recomendations needed... SloPoke The Fab Shop 22 09-26-2011 10:13 AM
ebay special combo welder plasma cutter gonzopb Tool Time 2 07-08-2008 02:57 PM
laser cutter for hire, not plasma 4bytruckin The Fab Shop 8 07-23-2007 08:53 PM
$375 to detail my 3rd gen.?!? Whitey13 95.5-2004 Tacomas & 96-2002 4Runners 31 09-28-2006 05:49 PM
plasma cutter BigA Tool Time 1 03-20-2006 09:33 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
