A little welding help please? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-13-2008, 03:01 PM   #1 (permalink)
WEINERDOGBONE's Avatar
I bought a small arc welder that's supposed to weld up to 3/16" steel.
So far, about all I can accomplish is to stick the welding rod to the steel repeatedly.
I can strike and arc but I can't keep it going for long. Should the welding rod stay in the pool when I create one? Should I be pushing the rod forward or pulling it towards me? Thanks for any input in advance.
WEINERDOGBONE is offline
Old 09-13-2008, 03:16 PM   #2 (permalink)
slowncurious-87's Avatar
what kind of rod are you using?
slowncurious-87 is offline
Old 09-13-2008, 03:49 PM   #3 (permalink)
Send a message via AIM to NicCantDecide
if its sticking, either you're holding the rod too close, the rod is too big, or the power's too low.
You're not really giving us enough info. There's a lot of good welding info if you search on google, tons of tutorials and general tips and tricks. You just have to make sure you have the right diameter and type of stick and you have your power settings dialed in properly for the piece you're trying to weld. Your welder should've come with a little card that shows power settings for different materials/thicknesses and maybe even different joints.
NicCantDecide is offline
Old 09-13-2008, 03:52 PM   #4 (permalink)
Team420's Avatar
^x2. I just learned to stick weld recently, and I can tell you....you will be sticking the rod to your work a lot... the best tip I got..was to sort of flick the rod to get an arc... kinda like striking a match, and stopping short, If you are using 7018, it will be tougher....my advice... get some 6011 and start practicing on scrap, then look at the box of welding rod, and see what it says to use for amperage. Also...I have found that with those little buzz boxes, its best to use a 3/32" rod, the 1/8" usually requires almost max what your welder can do. Also...just to get the idea...you might want to go down to the welding supply store, and get some easy strike rods, they burn quick, and wont make the stongest weld.... but it was helpful to me during the learning process. Good luck
Also... what type of welder is it, and what adjustments are there?
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock.
It's becoming an addiction.
Team420 is offline
Old 09-13-2008, 05:10 PM   #5 (permalink)
The welder has an adjustment knob for amperage that allows selections from 30 to 95 amps. I have tried the 1/8" rod and the 5/64". It sounds like I need smaller rod to get the setting hot enough. Thanks for all the help.
Old 09-13-2008, 05:18 PM   #6 (permalink)
whorider's Avatar
Yeah try 3/32" rod and up the amps. Striking like a match works great also. Burn lots of rod. I tend to arc weld with a really short arc, the puddle will almost push the rod along. Just burn lots of rod, and have fun.
__________________
I may be dumb but I'm not stupid.
whorider is offline
Old 09-13-2008, 05:30 PM   #7 (permalink)
just turn it all the way up and go like hell.
j/k
dont do that
Old 09-14-2008, 06:37 AM   #8 (permalink)
Team420's Avatar
I have found the lincoln 6011 3/32 rods work best with my little buzz boxes. I think the suggested amperage is like 65-95amps, I usually go closer to the 65, unless I'm welding thick metal, then I go up to about 80amps... I have found that using too high amps, makes it harder to lay a nice bead.
__________________
DD:
Project:
Team420 is offline
Old 09-14-2008, 08:39 AM   #9 (permalink)
Thanks for the replies. I think I know which direction to go now. I do appreciate it.
Old 09-14-2008, 06:03 PM   #10 (permalink)
4Crawler's Avatar
Yep, smaller rod should help. General rule of thumb on amps vs. rod size it 1 amp per 0.001" of rod diameter. So 1/8" = 0.125" ~ 125 amps or so. A 3/32" rod would need around 90 amps more or less. 6011 or 6013 are decent rods as is 7014 for starting out with:
- http://www.4crawler.com/4x4/CheapTri....shtml#Welding
In my welding class, we started with 6010 and that is a tough rod to work with (hard to get a nice looking bead as it is a fast freeze material), then went to 7018, which is also tricky to work with - hard to strike and arc and pretty runny bead which makes for fun with vertical or overhead welding. Then once we got through all that, we were told that those rods are both hard to work with and when you try something else, it is so much easier to work with.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-14-2008, 07:44 PM   #11 (permalink)
phildelfino's Avatar
Send a message via Yahoo to phildelfino
I acquired a bucket of welding rods. How do you tell if they are good and what size if they are not in any kind factory container?
Sorry for the small hi jack.
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs.
Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit,
Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap
http://www.cardomain.com/ride/3171939
phildelfino is offline
Old 09-14-2008, 07:47 PM   #12 (permalink)
well you can measure the diameter to figure out the size
as far as what kind they are, the sticks are usually stamped on one end with a number, but anybody above the age of 30 probably doesn't have good enough vision to read it without a magnifying glass.
Old 09-14-2008, 07:48 PM   #13 (permalink)
4Crawler's Avatar
Usually the rod type is stamped on the fat part of the rod, usually in the form of "6xxx" or "7xxx". Measure the diameter of the bare end to determine the size. You can always throw them in a warm oven for an hour or two to dry them out and see if they work on some scrap material. When I got my first welder, the guy gave me an old 50 lb. can of old 601x rods and they seemed to work just fine.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-14-2008, 07:49 PM   #14 (permalink)
Thanks, great assumption. I am 54 and do have old guy eyes.
__________________
Old 09-14-2008, 07:58 PM   #15 (permalink)
Send a message via AIM to eighty5yota
x2 on the 6011,6013 get the all position all metals rods from lincoln electric.
cant remember the name but you can weld most metals together.. except aluminum and i think stainless but cromoly is good
__________________
85 single cab longBOB 18'' gone, 4 inch peice-o-crap rancho lift, roger brown 3 inch body lift, 33x12.5x15 MT/R, flat black (apparently non responsive to radar guns =] ) 16 speaker sound system with 10 boston 6x9's, 2 phoenix gold tweeters,2 4x6 infinity's and 2 kicker 12's
2400w.
PERFORMANCE MODS:
heavy right foot, quick left foot
eighty5yota is offline
Old 09-17-2008, 02:15 PM   #16 (permalink)
Al's Chop Shop's Avatar
Send a message via AIM to Al's Chop Shop
nobody else mentioned it... but never pull a weld. always push.
Al
__________________
81 Toyota pickup
22r, 5spd, 4x4, longbed on 33's... custom suspension in the works.
79 Cherokee Chief Widetrack "Kronk"
TBI350, SM465, NP205, Hydraulic clutch, Hydroboost, Custom aluminum radiator, Flowtech headers, SOA D44HD w/ Hi-steer, D60, 36" TSL/SX's, LED tail conversion...
91 Chevy K1500 - The Hauler
TBI350, built 700r4, NP241, awaiting 4" lift...
90 XJ - 5.5" lift, 33's, bushwhacker cutouts, sliders, bumpers, winch...
08 Mazda CX9 - Zoom-Zoom!
Al's Chop Shop is offline
Old 09-17-2008, 03:56 PM   #17 (permalink)
I want to give a little credit to you guys. I wasn't having much luck with the little arc welder so I called one of my co-workers who has a son that teaches welding at the local community college.
He has a big freaking welder called a Miller Trailblazer. He took one took at my hobby welder and laughed his a$$ off. He said "You can't learn to weld on that toy". He then gave me about a 10 minute lesson with a real welder and I was able to weld up my bumper mounting brackets w/o much trouble.
You guys were right when you said get good tools and get someone with experience to show you how. I wouldn't have completed the welds on my bumper in 30 years of trying the way I was going.
Old 09-18-2008, 12:13 PM   #18 (permalink)
whorider's Avatar
Quote:
Al
Wrong. You only push a weld up hill. Other than that you should be pulling it or leading it. Just slightly, but, none the less leading it.
__________________
whorider is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Need some help welding ryanflknr Pre 84 Trucks 0 07-22-2008 04:31 AM
Welding ? 95toybox 86-95 Trucks & 4Runners 6 03-11-2007 07:19 AM
Welding drguitarum2005 Off Topic Talk 8 06-13-2006 06:13 PM
Welding help? Sbrut95 The Fab Shop 11 04-16-2005 06:38 AM
welding david in germany Maintenance & Repair Archives 5 10-11-2003 03:38 PM
2009 InternetBrands, Inc.
