| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How hard/safe is one person with spring compressors
#2 (permalink) |
It is not that tough of a job. Just make sure you rent some nice spring compressors and go into the job with some fresh arms, unless you have an impact wrench. I attempted the job with the tundra springs by myself and I ended up taking the shocks and springs to a shop and just had them assemble the strut. Keep in mind I was attempting to assemble it by myself without a vice, after already spending the majority of the day putting on my rear lift. Once you assemble the strut its a piece of cake, just make sure you put some thread locker on the 4 bolts that hold on the lower control arms.
__________________
-1998 4runner, Sonoran Steel #1 lift, 1" bl, 33x12.50 bfg a/t on black rims, custom dual exhaust with a vortex. -and a fast yz 125 -Daniel |
#3 (permalink) |
Well since your still on stock springs you may not need to remove the lower control arm bolts
__________________
#4 (permalink) |
Staff
You are talking about a vice.....DONT USE a bench vise. You can get actual quality spring compressors from any tool outlet. And dont skimp on the quality. You do not want to know what happens when that stuff breaks. Just ask my right knee
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#5 (permalink) |
It's not that bad at all, I've done springs/shocks by myself with no problems. The main thing is to take it slow and make sure you compress the springs evenly. In other words, don't crank one compressor down all the way and then the other.
__________________
Lance N. Vancouver, WA 1996 Taco 3.4 - 3"Revtek, 33's 190,000+ |
#6 (permalink) |
You need to be VERY careful when compressing the springs.
I have done a few and i won't do it anymore. A friend of mine was THIS close to losing a finger whne we did his civic once. The compressor slipped and rammed his finger hard, had it moved another half inch it would have come off. As it was he got some real bad cuts and it hurt for a good while. Personally i will take mine to a shop and have them do it.
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#7 (permalink) |
I use my press and homemade coil spring adapter to ensure that it can't slip out. Works like a charm and it is perfectly safe.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#8 (permalink) |
I bought a quality set and they included safety chains to prevent the spring from flying if they fail.
#9 (permalink) |
Thanks - just for clarification I was using the bench vice to hold the spring not to compress it...
#10 (permalink) |
i use one of these bad boys http://www.harborfreight.com/cpi/cta...emnumber=45860
granted its not one of those things you will use alot, but man is it handy when you do. ive used those spring compressors you can rent at autozone or wherever, but i just dont trust them. i too have had too many close calls with getting hurt. i was also suprised with the quality of that setup considering it was from harbor freight, but it seems to be made better than most HF tools anyways hope this helps |
#11 (permalink) | |
Quote:
__________________
| Tags |
| brunswick, coil, compressor, compressors, diy, hard, homemade, nc, raleigh, rent, safest, slip, spring, strut, tool, tools |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Censorship, work safe/family safe, other tidbits | Corey | Off Topic Talk | 25 | 11-13-2007 02:35 PM |
| Advice on coil spring compressors | lanai | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 09-11-2007 06:29 PM |
| Strut/coilover R&R: Spring Compressors - your thoughts | rimpainter.com | Tool Time | 16 | 01-11-2006 09:37 AM |
| A/C Compressors | Zo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-18-2004 04:21 PM |
