| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
How BIG is BIG enough for an AIR COMPRESSOR
__________________
REUNITED ONCE AGAIN WITH MY TOYOTA : D |
#2 (permalink) | |
Go bigger then you would ever think you will need because 5 years down the road when you want to run those big high cfm tools and you are stuck with the one that worked fine for your demands then, you will be kicking your self
Also buy one that is belt driven those direct drive ones are pieces of crap and louder then hell.
__________________
96 tacoma stock 2.7L, 5speed, manual locking hubs, Quote:
#3 (permalink) |
For shop duty, a 60gal or larger is preferred. It's best to get a 220v one, and hard-wire it into the garage. High-output 220v motors are cheaper than the same output 110v one, and also uses less amperage and therefore smaller gauge power wiring.
We have a 18cfm@100psi compressor, and it works great. Big enough for a repair shop with 2 or 3 bays.
__________________
- Brian 84 toy pickup mostly stock |
#4 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Quote:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#5 (permalink) |
I have a 33 gallon craftsman I got a few months ago. It does the job but its loud and it runs a lot depending on what your doing. It works with an impact and air ratchet just fine, haven't tried to paint with it yet. Just make sure you get a good hose not the crappy ones they give you.
#6 (permalink) |
I also have a Craftsman 30-something gallon upright direct drive compressor. It easily handles all the garage tasks I throw at it. Grinders, drills, chisels, 1/2" impact, tires, etc. For auto-body work or something else that will use large amounts of air for hours on end, I'd recommend something much bigger. For mechanical work, it's plenty.
Down side: It is really, really, really, really loud. I don't dare turn it on late at night (when I do most of my work) because it will wake up the entire neighborhood.
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift |
#7 (permalink) |
4CFM at 90 psi per tool OFF THE COMPRESSOR (not off the tank) you want to run. The tank size is just surge capacity - at the end of the day, you can only use what the motor compresses.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#8 (permalink) |
you can always get a motor or smaller compressor and hook it up to a huge tank, it will be a slow fill but wont run out every time you remove a lug nut
__________________
. . . I said lie, for me lying under a process tree . . . . |
#9 (permalink) |
http://www.4crawler.com/4x4/CheapTri...tml#HowMuchAir
I run a 12CFM/20 gallon tank compressor for my shop. Usually keeps up with most of the air tools I have.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 01-17-2009 at 10:34 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| horn, BIG, BIG, Loud sound......... | keithguts | 86-95 Trucks & 4Runners | 13 | 05-11-2008 07:32 AM |
| big rig in big trouble!!! PICS! | yotasavg | Off Topic Talk | 17 | 07-09-2007 01:15 PM |
| any big brake kits? i mean really big! | dsmjrv | 86-95 Trucks & 4Runners | 7 | 04-18-2007 10:04 PM |
| bodylift+big rims+big tires= max size?? | dexter | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 12-07-2005 05:54 PM |
| Rock crawling how big is to big? | Tomh4x4 | Offroad Tech | 58 | 06-03-2003 06:16 PM |
