The Great Welder Debate--Which one? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-03-2008, 08:22 AM   #1 (permalink)
hross14's Avatar
Alright--i decided it was time to get a welder and fabb needed bits and pieces myself....
Here is what i have been looking at so far
Hobart:
187, 210, and 210 Iron Man
Millermatic:
180 and 212
What will i be using it for.
Sheetmetal, Aluminum/SS Spool gun (very limited), and Mild Steel--i dont think i would be welding anything over 3/8"--whats you experience
So what have you found to work for you? Limitations on one machine or the other making you wish you had got something else?
Has anybody had a chance to use the AUTOSET with the Millermatics? What did you think?
It also needs to be semi portable--i know that kinda limits the Millers but....you can comment on that also.
Thanks
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is online now
Old 09-03-2008, 08:32 AM   #2 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
A 220V machine.
I have a Pro MIG 135 and a MM 251 and use both for different things but the 251 would do all of it.
Buy the biggest and best welder you can afford so you never need to buy another.
waskillywabbit is offline
Old 09-03-2008, 09:55 AM   #3 (permalink)
hross14's Avatar
Edit--i am deleting the Hobart 187 because it doesnt have plug and play spool gun...
I would love to buy a great huge do evrything machine but i only have a two car garage to work out of--and it is getting full--quickly
Has anybody not been able to weld something (rig wise) do to the welder not having enough power?
another question is when they say 3/8 inch material-will it really weld 3/8" material? Or is it going to come out looking like crap?
__________________
Old 09-03-2008, 09:58 AM   #4 (permalink)
run4her's Avatar
On my miller 212 ithe recomended setting for 3/8 is number 5, It goes to 7?
I love my miller it welds awsome.
__________________
1990 4runner. 42/14/r.17 irocks, spool in front. Sas, lc coils and triangulated 4-link. 1in bodylift, 7in front screen linked to 14in flip down in rear, Chopped, Bobbed 33". Wheelbase stretched 7".
1984 extra cab pickup. 7" suspension lift, 36" Radial tsl's, Bobbed 12"
run4her is offline
Old 09-03-2008, 10:05 AM   #5 (permalink)
saitotiktmdog's Avatar
I dont know how they work but I have seen combo, plasma cutter/tig/arc welders between 500 and 800 dollars. Arc welder is 220, not sure about the tig and the plasma cutter cuts up to 1/4 maybe more. Just an Idea. I have been looking at them myself. Currently I have a lincoln stick welder and a century mig. I want a plasma cutter.
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift front, t-bar crank(small), trail gear 4 inch rear lift with 6" shackles. ARB bull bar and warn winch, Quick lock rear, tru trac front 35x12.50 Pro-Comp Mud Terrains, 5.29 gears, snorkel, rock sliders
Planned mods. , T-case gears, ditch ifs
Beware the groove
Man, its a shame when folks be throwin away a perfectly good white boy like that.
saitotiktmdog is offline
Old 09-03-2008, 10:06 AM   #6 (permalink)
Darrin904's Avatar
I have a lincon 180 220v it's small in size but does alot, I've used it on alot of mini truck builds havent had any problems with it yet
Darrin904 is offline
Old 09-03-2008, 10:18 AM   #7 (permalink)
hross14's Avatar
Do you use the Set-O-matic feature on your 212? I am not going to be buying this welder alone so having a dumb down feature for the others that might use it would be nice?
__________________
Old 09-03-2008, 10:52 AM   #8 (permalink)
PISTOL1000's Avatar
Hobart 175 220v .............miller and hobart are the same -ish both are the best ez to get parts if needed . my welder works perfect no complaints here
__________________
1990 4 runner 4x4 cherry bomb / cold air intake/ twin electric push pull fan setup /31x10.50 x15/1000 watt stereo 15" sub/ D-Badged
PISTOL1000 is offline
Old 09-03-2008, 10:56 AM   #9 (permalink)
run4her's Avatar
Mine dosent have the auto set feature. i dident want it because i like to be able to adjust it.
__________________
run4her is offline
Old 09-03-2008, 11:13 AM   #10 (permalink)
Staff
MM 251 is not that big and will weld anything you want or need. I prefer the adjustable digital readout as sometimes dialing things in a bit makes a big difference in weld quality. If your friends can't read the chart on the inside lid of the welder for voltage and wire speed then they don't need to play with the welder.
Old 09-03-2008, 01:16 PM   #11 (permalink)
hross14's Avatar
Quote:
Ouch!!
I will take a look at the MM251
__________________
Old 09-03-2008, 01:26 PM   #12 (permalink)
hross14's Avatar
Holy Toaster it looks very nice but it is also $~3k. i think that is bigger and better than what i can afford....unless you know someone that wants to sell one for a smoking deal ~1000$+-
__________________
Old 09-03-2008, 01:56 PM   #13 (permalink)
blackspyder's Avatar
If you're able to pickup an old Millermatic 250 (almost the same as the 251 w/o digital adjustments). Check craigslist and local auctions and you can get a great deal. Your not gonna walk away with a good welder for less than $1500. If a welder doesnt do 1/4" it isnt worth buying. IMO
I priced the new Miller 100 series spool gun at approx $150 (the median between Arcet and AirGas) for the old 185 and old 250.
Not a fan of Hobart. You can buy it at Northern Tool and that says it all.
__________________
1988 4x4 Pickup
ISR/Battery-Intake Swap/216"c" Cam/ EGR removal/
blackspyder is offline
Old 09-03-2008, 02:21 PM   #14 (permalink)
hross14's Avatar
Does the old MM 250 have the intergrated spool gun control?
The MM 212 will do up to 3/8" and so will the Hobart 210. \
Why dont you like Hobart? Have you had bad experience with them?
Back in the day when i was welding we had a lincoln and a MM so i am not familiar with Hobart.
Then i was looking around and see clarke and other brands--is it best just to sticl to MM or HH?
__________________
Old 09-03-2008, 03:32 PM   #15 (permalink)
ScottyC's Avatar
Miller has always been known to be too conservative on their wall thickness rating. I have a 212 also(not the DVI), and I have easily welded 1/2" axle tubes to knuckles with it.
FWIW, I wouldn't consider the Hobart line myself. Mainly because it doesn't come with a long enough gun. It also comes with cheaper plastic internal pieces, but otherwise, its just about the same unit. MIller makes Hobart machines. The gun length was the biggest drawback to me with the Hobart.
3ft of gun length doesn't sound like a lot, but when you don't have to move a big ass welder around your rig to weld the opposite side it makes enough difference for me to be worth it.
I've run my 212 daily since I bought it a few months ago. I've already run through at least four 33lb spools of .030 wire with zero issues. Its a great machine and will do everything you throw at it including welding D60 knuckles back onto 1/2" tubes. I would HIGHLY recommend not getting the DVI though. Its not rated as high as the regular 212.
The 252 would be the only other welder I may ever consider and only because of the digital readouts and very minute tuning capabilities.
Lincoln also makes a very quality unit as well. I would say that its parallel in comparison to the Miller machines. I just like Blue........................
__________________
Scotty
http://www.addictedoffroad.com/
970-420-4198
Toyota Winch bumpers on SALE!
ScottyC is offline
Old 09-03-2008, 03:39 PM   #16 (permalink)
racingcameron66's Avatar
miller all day thats what i use at work
__________________
98 taco/ 4.88 gears/ locker/33x12.5r15 summit mud dowgs/ 4.5in tuff country sus lift/westin brush gard/westin nerf bars/ westin tail light gards/ma audio 1200 watt comp amp/ audiobahn aw1200q/dick cepeck dc-1's,pace setter header
Quote:
Originally Posted by agusgus3 View Post
That is the pinnacle of absurd and i love it! Just hope some state doesn't outlaw it like those homo truck nutz.
Quote:
Originally Posted by john rumbo View Post
i agree but toyotas push limits most jeeps walk the lines
racingcameron66 is offline
Old 09-03-2008, 03:43 PM   #17 (permalink)
ScottyC's Avatar
One more recommendation I would make is that you buy a machine from a local dealer like AirGas or General Air. I paid around $15 more for my welder than what I have seen on Ebay, but I can warranty it at my local AirGas. So, if I ever have an issue within the 3yr warranty period, I just drive it down the street to have it fixed instead of shipping it back to wherever you bought it and waiting forever to get it back.
__________________
Scotty
970-420-4198
ScottyC is offline
Old 09-03-2008, 04:14 PM   #18 (permalink)
My Miller 140 non-auto set is AWESOME. I have used 220v arc and I like this much better. There is little spatter, easy for a beginner to weld and I have welded 3/8's and this is a 110v. It took a third pass to really get it good but still.
And I agree get the biggest you can afford I regret it now that I spent 900$ on this one, I should've gone with the 251. And my mom even wanted to help a little to get that one. Oh well. I was referred to Miller by a friend who is a professional welder of 20 years and his friends agree so my vote is for Miller.
Mic09dcsm is offline
Old 09-04-2008, 07:35 AM   #19 (permalink)
hross14's Avatar
Alright--it is settled then--I am going with the Miller 212.
Its funny how the thought of new tools makes me feel giddy like a school girl--Now if i could just find a hot catholic Nun
If you here of somebody letting one go--drop me a line...other wise i will be saving zee pennies
Thanks for the input guys
__________________
Old 10-06-2008, 07:41 AM   #20 (permalink)
hross14's Avatar
FYI--put in the order--but glad i waited becuase i was going to get the MM DVI2--but opted for the PASSPORT Plus and a Spool Gun (100 model).
This is Gonna be nice
__________________
Old 10-07-2008, 06:26 PM   #21 (permalink)
tc
tc's Avatar
Great choice - the Passport is AWESOME. Having the switchable plugs for either 110V or 220V is VERY nice.
One of the COTTORA guys has a Passport, I like it better than my Lincoln 180. Seems to have better arc control and mine seems to like to put down A LOT of wire.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-09-2008, 11:33 AM   #22 (permalink)
TC4RNR's Avatar
I own a MM250 and use a MM250MP at school and at school, we abUSE that thing hard. the difference between these two is that the 250MP(Micro Processor) has a digital dail. according to the instructor he prefers it without the digital dial because it has one less thing to fail.
i don't have hands-on experience on the newer series 212 and 251 welders, but everybody says for a welder to be used in a shop(not in the field), bigger is alway better.
__________________
http://i172.photobucket.com/albums/w...gca/agreed.jpg
94 4Runner, SR5 3.0V6, 4WD, 5spd: SOLD
99 4Runner, SR5, 3.4L 4WD, 5spd. LC80 wheels, SS 1.2 lift, Marlin 1200 Clutch, ARB front bumper, BruceTS rear bumper, roof busket, hitch mount tire carrier, Tundra Brakes, Brembo rotors, BudBuilt skid, Lightforce 240 Blitz, PiAA HID, Stubb's HD-SKO sliders. ScanGauge II
04 4Runner SR5 V6 4WD. 265/75/16 BFG KO, FJC coils and silver Bilstein shocks, Scion H/U.
TC4RNR is offline
Tags
212, 250mp, autoset, craigslist, millermatic, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
O2 sensor debate...what's the skinny? thook 86-95 Trucks & 4Runners 21 05-01-2008 01:35 AM
WabFab=great customer service and great products!! ocdropzone Customer Feedback For Vendors 0 07-12-2007 08:00 AM
Mental debate 4x4yoda The Classifieds GraveYard 3 12-09-2006 06:44 PM
FJ Debate Intrepid FJ Cruiser 97 08-13-2006 04:13 PM
The debate thread MeinPappa Off Topic Talk 33 07-25-2005 11:25 AM
2009 InternetBrands, Inc.
