Free Welder - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-02-2008, 08:35 PM   #1 (permalink)
phildelfino's Avatar
Send a message via Yahoo to phildelfino
Free Welder
Just got a free welder. It's a "Made in Italy" Chicago Electric Utility Arc 1400. It's 110 volt and puts out between 30 and 100 amps.
Anybody heard of this unit?
Anybody have experience with it?
What kind of 110volt circuit do I need to run it ( amperage requirements )?
Thanks,
Phil
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs.
Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit,
Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap
http://www.cardomain.com/ride/3171939
phildelfino is offline
Old 09-02-2008, 08:38 PM   #2 (permalink)
apalmer1's Avatar
chicago electric is harbor freight brand. i would run it off of the highest amperage circuit you have.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
92 mazda B2600i 4x4 absolutely mobs.
81 ford bronco drinks gas
90 mazda mx-5 all original.
when in doubt, tach it out.
apalmer1 is offline
Old 09-03-2008, 10:07 AM   #3 (permalink)
saitotiktmdog's Avatar
never used their welders but have had great success with the angle grinders. Got three of them.
__________________
1994 toyota 4x4. 22re turbo (sds em4, intercooler, steedspeed manifold, garrett t3) 4 inch procomp stage two lift front, t-bar crank(small), trail gear 4 inch rear lift with 6" shackles. ARB bull bar and warn winch, Quick lock rear, tru trac front 35x12.50 Pro-Comp Mud Terrains, 5.29 gears, snorkel, rock sliders
Planned mods. , T-case gears, ditch ifs
Beware the groove
Man, its a shame when folks be throwin away a perfectly good white boy like that.
saitotiktmdog is offline
Old 09-03-2008, 10:24 AM   #4 (permalink)
algranger's Avatar
nice find. that is known as a cheap brand but should do the job just fine cause theres not many working parts or anything that can go wrong on a stick welder. as was said before id just go for the highest available circuit and if possible dont use an extension cord, it reduces your amperage.. well unless you get a big ass one i have a big fat 50 footer for my welder thatworks pretty good it called Yellow Jacket
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 09-03-2008, 10:29 AM   #5 (permalink)
4Crawler's Avatar
Should be a name plate on the back of the welder with circuit requirements, likely 120 volts with 20 amp circuit. Be sure to get small diameter welding rods, probably 1/16" or 3/32" as I doubt that the more common 1/8" rods will work well, general rule of thumb is 1 amp per mil of rod diameter (so 1/8" = 0.125" or 125 mils or amps). I've only found the smaller welding rods at welding supply shops.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-04-2008, 05:01 PM   #6 (permalink)
Thanks for the comments and tips. I am new to welding and didn't know they came in different diameters.
__________________
Old 09-04-2008, 05:06 PM   #7 (permalink)
ryantowry_81's Avatar
i have a little 80 amp chicago electric flux core wire feed and it has made many bumpers!!! even did decent up to 1/4" if you take you time and run a big bead. I have had mine for 2 years and gone thru 4 spools of wire and still working perfect. even took it out on the trail with a generator and ran it that way once worked good!
__________________
the "Turtle":
now the mutant turtle.....
84 ex cab
63" chevies
Rears Up Front
Square Drive Shaft
d60f 14 bolt rear welded both with 5.38's
home brew hi steer
42x15-15 TSL's
TBI 4.3 V-6
pretty much stock!!!
Denali offroad club:
http://www.denalioffroadclub.com/for...orum/index.php
ryantowry_81 is offline
Old 09-04-2008, 06:20 PM   #8 (permalink)
Quote:
Cool to know... How big of a generator?
__________________
Tags
1400, arc, chicago, electric, free, utility, welder
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Free mig welder readywelder Tool Time 2 12-15-2007 09:36 AM
Looking at this welder: ClemsonToy Tool Time 23 10-30-2005 12:30 PM
What welder to get? corvettelvr73 The Fab Shop 8 10-03-2004 07:02 AM
2009 InternetBrands, Inc.
