Drilling Metal: Take 2 - What kind of bit? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-21-2006, 12:58 PM   #1 (permalink)
Send a message via AIM to garrett1478
well i see theres a drilling metal thread a few threads down, but this is a bit different.
to put it shortly, what the HECK kind of drill bits are you guys using to drill steel?
me and chris need to make shackles for his truck. out of 3/8" plate... the holes need to be 9/16".
so we got a $20 bit from a hardware store, advertised to drill metal, 'good for drilling stainless steel'
yeah right. we got 1 hole done and its like the bit turned off. it wouldn't do a thing. we used cutting oil, stepped up in size a few times...
what's the secret brand to use?
garrett1478 is offline
Old 05-21-2006, 01:39 PM   #2 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
What's it made out of? I hear that Cobalt bits do a real good job.
__________________
:Marko:
Supercharged 98 4Runner SR5 4x4 3.4L
4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator
XM Satellite Radio (Roady 2)
:: Autometer Boost Gauge :: Color Keyed Spoiler
TOYOTA|moving forward
marko3xl3 is offline
Old 05-21-2006, 01:47 PM   #3 (permalink)
photoleif's Avatar
Send a message via AIM to photoleif
i always, ALWAYS use titanium nitride bits. they do a bang-up awesome job on wood and metal. they go through aluminum like it's not there. they eat up hardwood readily if you clear 'em often, and going through steel is far far easier than with a traditional high-carbon bit. i got a decent-enough set at harbor freight for $20ish -- 1/16 to 1/2 by sixteenths. kicks butt.
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console
sometime: rear locker
some sometime: retire the IFS
My truck page
Photography:
http://www.aspen-graphics.com
photoleif is offline
Old 05-21-2006, 02:21 PM   #4 (permalink)
getitdone's Avatar
The bit we used was cobalt. It was really sweet for that first hole. Metal chunks were flyin. We seriously stopped ever 10-20 seconds and re oiled the hole with cutting oil. The rpms where pretty low too. When it stopped working, it was all of a sudden. Like in between oilings, it just wouldn't do anything but ring.
This can't be the only way. I will lay down the green for a professional solution. I have to get these holes cut.
What I have used so far:
the generic steel ones - they suck.
titanium - doesn't last and really wasn't that effective
cobalt - the bit from heaven for just one hole!
I am wondering about carbide but I can't keep buying these 20 dollar bits!!!!
Please help.
__________________
Chris Fischer
3D 85 4Runner SR5 | 33" BFG M/T on flat black rims | Chevy springs | Custom Grab cage with overhead cb mount | Custom fabbed center console | Freshly rebuilt axle with IFS hub/caliper swap | Rock Sliders | Lots more...
In Colorado, Dig.
getitdone is offline
Old 05-21-2006, 03:03 PM   #5 (permalink)
kyle_22r's Avatar
i like the black oxide bits, because you can re-sharpen them easily. titanium works good, too.
my secret: go real slow, and keep it oiled, and put pressure on it. high speed does nothing but round the bit off.
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 05-21-2006, 03:13 PM   #6 (permalink)
getitdone's Avatar
How do you resharpen yours?
__________________
Chris Fischer
In Colorado, Dig.
Old 05-21-2006, 04:41 PM   #7 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Drill press.
Generous cutting oil, NEVER let it get dry...contstant flow.
High speed steel bits. Hardware store drill bits are WAY WAY WAY overpriced and usually a POS. Find a local contractor supply store, bolt specialty shop, somewhere that sells high quality bits. I can get a high speed steel 1" bit for under $15.
Drilling a 9/16 hole is too big...start small and work up to the 9/16. Depending on your setup, I would have gone 3/16, 3/8, 9/16 or something like that.
I've got one 3/16" drill bit (titanium tip) that has drilled hundreds of holes, still as sharp as it ever was.
I frequently drill 3/16" thick plate (slider adapters and the like) and I've drilled thousands of holes over the course of the past couple of years...same DeWalt drill bits up to 1/2" by 1/64" (for metal) and a few larger high speed steel bits for select sizes.
Sounds like you just burned up the bit.
waskillywabbit is offline
Old 05-21-2006, 05:51 PM   #8 (permalink)
getitdone's Avatar
Holy moly! I have the opposite success rate that you do.
So this is the recipe:
drill press,
high speed steel, titanuim tiped(purchased from contactor or equivalent)
about 3 steps to get to 9/16,
constant flow of oil
Am I missing anything?
Sounds too good to be true. I will throw it all down tomorrow after work.
__________________
Chris Fischer
In Colorado, Dig.
Old 05-21-2006, 06:00 PM   #9 (permalink)
Staff
Constant lubrication just means don't let it get dry...doesn't mean drown it...a little cutting oil goes a LONG way. Make sure you drill press speed (if it has an adjustable speed) is also set for drilling metal...as the setting will be a LOT slower than wood. On mine you move the belts on the pulleys.
You don't even need titanium tipped necessarily, just high speed steel. I have the smaller bits in titanium tips, the ones that I use repeatedly...like 3/16, 1/4 and 5/16.
A little more work saves you a lot of work in the long run...and money on drill bits.
Old 05-21-2006, 06:02 PM   #10 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
Its unlikely that you hosed a cobalt bit.
It probibly got hot and got a chip "welded" to the cutting edge.
I sharpen mine on my drill doctor and split point anything above 1/4"
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 05-23-2006, 05:21 PM   #11 (permalink)
getitdone's Avatar
Well, I found a sweet shop. They weren't open untill today. I got some killer bits at a fraction of the cost. Thanks Brian!
When I got home and fired em up, I was somewhat dissapointed. They did nearly nothing. After another trip to the shop, we decided that the "scrap" that I got wasn't mild steel. It is something else, like maybe cast iron or something. Anyway, the only results I could get was with a solid carbide bit that was like 2 inches long. He only had just smaller than 9/16 so I have to ream the holes out to finish. I am drilling holes in 3/8 plate and 1/4 plate. Another thing that backs up the not mild steel theory is that the 1/4 cut like butter when done properly(described above) I was so amazed.
So tonights lesson, make sure you know what your getting from the scrap pile before you drill it.
__________________
Chris Fischer
In Colorado, Dig.
Old 05-23-2006, 05:24 PM   #12 (permalink)
Staff
Quote:
Sounds like a "commercial" for teen abstinence to me.
Old 05-24-2006, 09:20 AM   #13 (permalink)
SlightlyModified's Avatar
I have continous lubrication. Set my press for the slowest speed. Last week, building ladder racks. I drilled 24 1/2" holes in 1/4" steel plate with one cheepo bit, without re-sharpening. I am having really good luck with a set of tin coated bits made by Clarke. Bout them at tractor supply. Alaways use several sizes to Step up.
__________________
81 pickup, 33's, 3" drivetrain lift, 5 speed, see buildup here http://www.yotatech.com/showthread.p...1#post50392798
94 f250 4x4, 285 BFG a/t's, 7.3 turbo diesel
05' Honda Rincon 4x4 atv, procircuit t4 exhaust, 26" ITP mudlite's.
78' VW Rabbit, Veggie fuel conversion (in the future)
74' VW Beetle, all original (for sale)
Alot of Toy parts for sale, PM for info and prices.
SlightlyModified is offline
Old 05-24-2006, 09:36 AM   #14 (permalink)
snap-on's Avatar
Have i mentioned comming accross the pice of Titaium sheetmetal back in school at the ME shop?
the local metal supplyer used to donate cut-offs and left over sheet crap like that for us to use on projects.
So some kid goes in the back finds a piece of 18" sq sheet that he thinks is AL cause its light and not rusty.
proceeds to burn up four 1/4" bits and hardly divit the surface. The shop machinest comes over and bout has a fit. "WHAT THE HELL ARE YOU DOING!?!!" were like.. makeing a bracket.... "OUT OF TITAIUM!" he says... were like.. oh that would be why it wont cut we tossed it back in the pile and dug out some AL.
__________________
snap-on is offline
Old 05-24-2006, 09:49 AM   #15 (permalink)
Staff
Titanium is just a TAD pricey these days.
Old 05-24-2006, 10:40 AM   #16 (permalink)
Epic Ed's Avatar
I'm still trying to drill holes through the A-arm support truss from Schaefer. It is manly work! I punched the first thre 3/8" holes through the beam, the front side of the frame, the back side of the frame, and the other side of the beam. Probably an inch of steel total, and it was serious work even with titanium drill bits. I don't have much experience with kind of things, and then someone suggested I drill a 1/4" pilot hole. I tried that this weekend and still haven't made much progress on the last hole. I wasn't aware that slower is better and considered cutting oil, but there's no way for me to really get a good shot at the drilling location.
I hate to blather on without any solutions, but at least know that you're not the only knuckle-dragger out there unsuccessfully trying to drill through steel.
Ed
__________________
'95 4Runner|32x11.5 BFG TA KOs|Hi-flow Cat|Dynomax muffler; 2.25" exhaust| Downey Headers|4.88 gears |Detroit EZ locker |Detroit TruTrack|BJ spacers|Downey HD coils|2" rear spring spacers|Rancho RS9000X/RS5000s|WARN hubs|TJM T15
Epic Ed is offline
Old 05-26-2006, 09:21 PM   #17 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
knuckle dragger.......
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 06-05-2006, 08:39 AM   #18 (permalink)
86SR522REEFI's Avatar
Send a message via AIM to 86SR522REEFI
I just use a titanium step drill bit whenever I have to drill metal. AND LOTS OF OIL
__________________
<(((Mark)))>
1997 4x4Runner
Limited 5-VZE
Auto 134,000 Miles
Quote:
Originally Posted by Leslie Nielsen
I am serious, and don't call me Shirley.
86SR522REEFI is offline
Tags
115, bit, cobalt, drill, drilling, freight, harbor, hole, kind, metal, piece, set, threads, tips, wwwdrillingmetalcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Drilling new grommets through firewall Erich_870 Vehicle Audio & Home Entertainment 7 02-19-2007 07:29 PM
High pitch 'metal on metal' squeel Tun2k Newbie Tech Section 4 10-24-2006 08:24 AM
Drilling metal drguitarum2005 Tool Time 6 05-16-2006 08:38 AM
ANWR Drilling GodwinAustin Off Topic Talk 66 03-18-2005 02:00 PM
Drilling into receiver stock Corey 95.5-2004 Tacomas & 96-2002 4Runners 5 10-28-2002 08:47 AM
2009 InternetBrands, Inc.
