| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Drilling metal
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#2 (permalink) |
Use a center punch.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#3 (permalink) |
start with a split point drill bit or something 1/8 or under as a pilot hole.
for thick steels your gonna need to step the holes up for best results. (1/2" hole should go something like center punch, 1/4-3/8-1/2)
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#4 (permalink) | |
Quote:
and are you using that drilling oil stuff? the name escapes me right now. keeps the drill bit cool too
#5 (permalink) | |
Quote:
What he said, athough I can't remember the name off hand either...
__________________
CJ ...<>< 03 DC TRD Tacoma 4wd with a bunch of junk. SOLD 1964 Chevy Biscayne, 230 I6, lowered, satin black, old-school legit. Just wheel the stupid thing!!! But do it responsibly, ok? My band: Road Worn Saints |
#6 (permalink) |
The oil stuff is called cutting oil, right? That stuff definitely helps. Keep both hands on the drill and brace your arms against your ribcage, that kinda helps me keep things lined up.
I usually star larger holes with my trust 1/8" bit. I find step drill bits to be great for metal too. |
#7 (permalink) |
Center punch is the way to go, split points are nice also. Cutting oil/tapping fluid keeps bits from getting dull. We also use "Tap Wax", it is a cutting wax that melts as the bit gets hot. Less mess, as the wax doesn't fling around like oil will, and the wax stays on the bit. Like death runner said "Step drill" bits make really good tools for doing large holes up to 3/4 inch with out having to change bits.
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
| Tags |
| cutting, drill, drilling, drills, fluid, fluids, hole, holes, large, metal, oil, pictures, put, tap, wax |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Retrofitting A/C ? about drilling holes | paxil4x4 | 84-85 Trucks & 4Runners | 2 | 02-17-2007 07:46 PM |
| High pitch 'metal on metal' squeel | Tun2k | Newbie Tech Section | 4 | 10-24-2006 08:24 AM |
| Drilling Metal: Take 2 - What kind of bit? | garrett1478 | Tool Time | 17 | 06-05-2006 08:39 AM |
| ANWR Drilling | GodwinAustin | Off Topic Talk | 66 | 03-18-2005 02:00 PM |
| Drilling into receiver stock | Corey | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-28-2002 08:47 AM |
