Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
DIY precision straight edge
Old 04-29-2010, 06:39 PM
betelnut's Avatar
I've been trying to find a 18"-24" precision straight edge for about $40 or less (delivered), and it's not easy to do. Typically, a 24" edge ground to 0.001" (really bad!) costs at least $50 before ship.
There's a pretty cool writeup here on making your own:
http://home.comcast.net/~jaswensen/m...ight_edge.html
As far as I know, the 1/4"x2" steel stock at e.g. Lowe's are hot rolled steel. A 6' piece, enough to make 3 2" edges as described here, would cost probably $15 or so, and a tube of lapping compound a few bucks more.
I'd guess that kind of steel stock should be accurate to within 0.002" over 2', guessing by the piece I have here and comparing it to other flat surfaces.
Any thoughts?
Old 09-09-2013, 08:37 PM
sp1
sp1's Avatar
straight edge results?
So did you follow through with the straight edge project?
I've lost mine or it grew legs and ran off...lol
I do have 2 pieces of stock that should be really close.
sp1
Old 09-10-2013, 05:47 AM
betelnut's Avatar
I cheated and got a 24" from Rockler that cost about $40.
To originate a straight edge, you need to start with three pieces of stock. Lapping just two together could leave you with an arc shape!
buckz6319
08-05-2017 03:50 AM
live4soccer7
05-11-2016 06:52 PM
Chicken12
10-14-2015 03:54 PM
zanzabar0
10-11-2015 02:56 AM
_Nicco_
09-21-2015 03:06 PM
Quick Reply: DIY precision straight edge
