Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Buying a new welder: Flux vs. Gas
Old 12-02-2011, 12:04 PM
new2cruzers's Avatar
Originally Posted by wyoming9
And your point was??
If you can stick weld you are ahead of most!
Well, I said I learned on a Lincoln stick about 20 years ago, I'd didn't say the welds looked great, besides I'm older and wiser now (well at least older). Since running a Mig on gas and flux I think if given my choice and the fact I'm buying my own, I going with a Mig that can be used for a variety of things. I agree, a stick will weld heavy stuff and given the right rod can be used on different things, but if I am throwing out the money I want something I can weld sheet metal (say bobbing a bed) up to my planned solid axle swap. Not to mention, a tube bender, notcher (read: tube bed, doors,etc.), and maybe a "plate" winch bumper is in the future. Projects that require lots of welding, you'll find yourself trying anything you can to cut down on welding/weld clean up time. I like the Mig for ease of use and flexibility. I guess it's just personal preference.
Old 12-06-2011, 01:56 AM
krawlinn87's Avatar
I just purchased the Hobart Handler mig and couldnt be happier - Hobart's are made by miller and depending on the unit you're buying, some even come with miller guns (mine did). Warranties are the same and I can burn 1/4 no problem.
I researched the different brands prior to purchasing my welder and Hobart's cant be beat.
Next on my list is the Hobart ez-tig. Same thing as the Miller tig but comes with a foot pedal.
Old 12-06-2011, 03:23 PM
peow130's Avatar
I ran a lincoln 140 amp or 135 amp with flux and had no issues welding 3/8ths. In fact, most of the welds on my neighbors trailer have all held up to the 3 tons that he had on it. The only one that broke was a stake pocket.
Old 01-07-2012, 06:12 AM
Wade74's Avatar
I have a buddy that owns a MM180. He loves it. He has welded two SAS's with it and hasn't had a failure yet. I own a MM140 and a MM211. I love them both. The MM180 should have all the power you need.
Old 01-29-2012, 03:23 AM
  #25
wyoming9's Avatar
Red face
kind of a moot question!!
Just buy it set up to run the hard wire (gas shielded)
Then if you feel the need to run self shielded wire just change the welder to straight polarity .
Run to your hearts content or the spool runs out.:jessica:
mussy01
12-13-2016 08:20 PM
pyramid
07-30-2015 10:05 AM
Yota.Jay
07-23-2015 08:08 PM
daddio
07-18-2015 10:20 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: Buying a new welder: Flux vs. Gas
