bought a new soldering gun.. HELP!!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-05-2008, 08:47 PM   #1 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
bought a new soldering gun since i was sick of the pencil. its a radioshack model, 2 selectable heat. and i cant figure out how to use it. the rosin core solder just isnt sticking to wire. have tried with the flux, and without it. works better without the flux, but not much. i want to get used to this thing before i repair some connections the PO did under the hood. and is the label correct in saying it cannot be used for more than a minute at a time, and for every minute its on, it needs 4 minutes to cool? HELP!!!
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 01-05-2008, 09:10 PM   #2 (permalink)
High Water Drifter's Avatar
solder problem
I have some experiance soldering, so hopefully i can help. I solder alot of components on circuit boards(resistors, led's, switches, etc.) First clean hot tip w/ damp cloth. prime the hot solder tip w/ solder(use VERY THIN gauge solder, thin as a paper clip).Of course you want to heat the existing solder contact point on one side and add solder to hot solder joint from the other side. The solder doesn't really contact the tip of solder pen ,just the hot solder joint. To remove lay down wick on solder and aply tip of solder pen. make sure to clean tip each time and prime. It's key to get very thin solder! Hope this helps
__________________
97 4runner LTD, rear locker, SS# 7.1, TJM T-17, Bent Up sliders, sport hood, Jaos spoiler, True Flow intake/filter, magnaflow exhaust, Nitto T/G 285's, and some other mods...
99 tacoma sr5 xtra cab 2.4L 2wd (gas saver!)
90 4runner 4wd w/ some mods. (sold)
97 tacoma 2wd (sold)
"ya know, they've done studies ....60% of the time it works every time."
"the beatings will continue until morale improves"
High Water Drifter is offline
Old 01-05-2008, 09:14 PM   #3 (permalink)
so the solder from walmart in the tube thats 1mm thick isnt the best stuff to use for wiring huh? maybe thats my problem....
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-05-2008, 09:45 PM   #4 (permalink)
I don't have the specs right now, but the solder that works best for me is as thin or thinner than a small paper clip. it heats up alot faster, flows better, and resists solder balls.
__________________
Old 01-05-2008, 10:01 PM   #5 (permalink)
i get a lot of solder balls... does that mean my solder is too heavy?
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-05-2008, 10:04 PM   #6 (permalink)
CJM
CJM's Avatar
YOu heat the item to be soldered, not take the solder and bring it to the item.
I have that radioshack model, 15 and 30w selectable, pos. I bought a good one for 45 bucks or so and was amazed..
Tin the soldering tip (use small amnt of solder), then heat wiring. Honestly if your not wiring anything to important I like crimp on connectors better.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 01-05-2008, 10:14 PM   #7 (permalink)
linuxrunner's Avatar
I started with the really cheap one from radio shack... i killed it preatty fast.
Next i moved on to a $20 gun i found at home depot and i killed that in about 2 months.
At this point i figured i would invest in a really nice gun... blew $75 on a good electric gun... lasted 1 year but i killed it trying to solder wires as thick as my pinky finger (it was an emergency).
Last gun i got was gas... it ROCKED!!! And guess what... i killed it
I am in the market for a high end gas soldering gun right now, and i would suggest looking for a non electric gun, they can be pretty cheap and have a 100% duty cycle, And the best part is NO CORD!!!
__________________
88 4runner 22re
Quote:
"Ditch that IFS because it is already crap and go for an SAS! (Single Axle Swap)"
linuxrunner is offline
Old 01-05-2008, 10:14 PM   #8 (permalink)
230/150 watt soldering gun. dual heat.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-05-2008, 10:27 PM   #9 (permalink)
CJM
CJM's Avatar
THen your not soldering right ozzy..
__________________
CJM is offline
Old 01-05-2008, 10:28 PM   #10 (permalink)
thats what im thinkin.....
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-05-2008, 10:28 PM   #11 (permalink)
CJM
CJM's Avatar
Like I said, clean the tip and tin it using a small amount of solder. THen heat the wires and touch solder to them. Flux is only for pipes btw.
__________________
CJM is offline
Old 01-05-2008, 10:50 PM   #12 (permalink)
ok so you dont heat the top of the wire then apply the solder to the wire right next to the tip.. you heat from the bottom then apply the solder on top... how do you know when its ready? i know NOOB question flame suit engaged
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-07-2008, 05:10 PM   #13 (permalink)
ok found the problem... it wasnt me, the gun isnt heating up high enough. had my mechanic try to use it (has been soldering for like 40+ years) and he said its not heating correctly, and to return it.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-07-2008, 05:23 PM   #14 (permalink)
phildelfino's Avatar
Send a message via Yahoo to phildelfino
I like to sand the tip lightly before I even turn the thing on. Then heat it up on the highest setting. Apply solder to the tip ( tinning the tip ). If the items you want to solder are hot enough the solder flows to the heat. Use as little solder as possible. If your gun or iron is not getting hot enough then the best solderer will have problems. A wet rag, sponge or paper towel should be kept near to clean the tip before or after each solder.
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs.
Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit,
Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap
http://www.cardomain.com/ride/3171939
phildelfino is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Proper soldering techniques Sherpa 95.5-2004 Tacomas & 96-2002 4Runners 26 01-13-2005 01:56 PM
Soldering wholes on radiator red 59 95.5-2004 Tacomas & 96-2002 4Runners 5 06-14-2004 09:03 PM
Soldering gun and othe electrical stuff joshik Off Topic Talk 6 10-16-2003 04:50 PM
2009 InternetBrands, Inc.
