Anyone running hard shop airlines...copper...etc..?
I put my 80 gal vertical tank Ingersoll-Rand compressor in a shed outside my garage so I don't have to listen to it. The outlet is halfway up the tank and a drain on bottom that I drain daily at least. I ran 3/4" copper from the compressor about 30' on a down slope to another drain.
I then had it turn 90 degrees into the wall of my garage and 90 degrees up the inside wall and at an upward angle towards the ceiling. It loops around the ceiling and then down to drains at the bottom of several down legs.
They make silencer intake filters to help keep noise down. Another way you can do it, is to just plumb your intake filter to the outside of the building. Almost all the noise comes from the intake filter.
I have run the pipes up off the main line too, it helps because any accumulated water won't just drop into the down pipes.
skoti89
07-08-2015 12:05 AM
skoti89
07-06-2015 07:45 PM
