YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-11-2007, 06:10 PM   #1 (permalink)
isaac338's Avatar
is a 70 amp welder big enough?
Canadian Tire has a 70 amp mig on sale for $300, including a gas kit. I want to buy a welder for some basic body work, but I might do things like weld up some sliders, or patch some rust spots in my frame (maybe near the rear for a trailer hitch).
Is a 70 amp welder gonna do it or is it a waste of money? I can't afford anything bigger so it's this or nothing, really.
Thanks for the advice.
__________________
1994 Xtracab pickup, 180,000km
1989 4Runner, 300,000km - sold
isaac338 is offline
Sponsored Links
To remove this ad, register today!
Old 07-11-2007, 07:08 PM   #2 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
18-gauge to 3/16" thick if you use flux core wire on the thicker stuff
waskillywabbit is online now
Old 07-11-2007, 07:52 PM   #3 (permalink)
isaac338's Avatar
how thick's the frame on a 4runner? i'll probably only need to weld a few small patches in the very rear of the frame.
is it worth it?
__________________
isaac338 is offline
Old 07-11-2007, 08:04 PM   #4 (permalink)
NCSU-4runner's Avatar
Send a message via AIM to NCSU-4runner
thats plenty for sheetmetal and maybe some minor frame repair, i wouldn't try to highlift off sliders that were welded on with something that small. pony up two hundred more and get a 140.
__________________
Jeremy,
94 4Runner Turbo
Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap
My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum
One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first.
NCSU-4runner is offline
Old 07-12-2007, 06:13 AM   #5 (permalink)
isaac338's Avatar
I read some threads on WeldingWeb and it seems to be frowned upon. Looks like I'm saving my pennies for a mig pak
__________________
isaac338 is offline
Old 07-22-2007, 10:30 AM   #6 (permalink)
44Runner's Avatar
Send a message via AIM to 44Runner
if you are going to invest in a MIG welder the cheapest I would go is the Hobart Handler 187. Great welder and good for 99% of people. Can do everything you want to do with it with ease and is capable of building a full tube buggy if you wanted. One thing I find SUPER annoying about cheap MIGs is generally if the switch is on the wire is hot. A good welder the wire is only hot when the trigger is held down. IMHO any box than is 115 volt is a waste of money. 230 is the only way to go.
70 amps is definitely not enough and is a waste of money. You should be looking for AT LEAST twice that...
__________________
Buggy in progress - 22RE on pane, A340, 4.7, 8"s, 4Ds
1989 4Runner 3.slow 5spd and big plans...
2005 Ram 2500 4x4 CTD 6spd QC SWB
44Runner is offline
Old 08-12-2007, 04:01 PM   #7 (permalink)
razrwild's Avatar
http://www.homedepot.com/webapp/wcs/...=8125&D=welder
what about something like this?
they also have a 115v that's rated for 5/16th but i'm fairly new to welders and home depot has these on sale most all the time
__________________
89 4runner 22re 5spd bone stock 224k miles DD
razrwild is offline
Old 08-12-2007, 05:48 PM   #8 (permalink)
JamesD's Avatar
Quote:
Can you explain why? I never understood why you wouldn't want to have the gas.
James
JamesD is offline
Old 08-12-2007, 07:04 PM   #9 (permalink)
Sponsoring Member
Most wire welders will use bare wire with a shielding gas, very clean, or a wire coated with flux (built in shielding gas), pretty messy.
My Pro MIG 135 will weld up to about 20 gauge single pass with the bare wire and shielding gas or up to 5/15" thk single pass with the flux core.
It just really depends on what you are welding on...on an axle, I want nice clean welds so I will use MIG (preferably my MM 251) but for something like welding up a piece of busted farm equipment, flux core.
Old 08-13-2007, 06:21 PM   #10 (permalink)
44Runner's Avatar
This is kind of true. The wire isn't "coated" like a stick welding rod, the flux is in the middle of the wire, hence flux "core" wire.
The whole answer to your question is actually pretty complex. I'm sure you could read for days on the net about welding and how to go about it.
Flux core wire does have some advantages over solid wire. There are two basic types of flux core as well. One is made to be used with a sheilding gas and one is made to be used on its own. One large advantage of self sheilded wire is it can be used outdoors of course.
I use solid wire because I weld in a garage, don't do much out of position and I work with clean metal. If this was not the case I would be looking at some form of flux core...
__________________
44Runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Bridgestone & Michellin 245/70/16 tires kevin444 Axles/Suspensions/Tires/Wheels 0 10-19-2006 10:58 AM
4.30 & 265/75 16 = 4.10 & 265/70 16 ? goldtaco9 95.5-2004 Tacomas & 96-2002 4Runners 23 02-06-2006 10:48 AM
60 or 70 Amp Alternator in '90 4Runner? Optimus 95.5-2004 Tacomas & 96-2002 4Runners 2 03-13-2003 03:55 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
