YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Product-Gear Reviews > Product Reviews
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-23-2007, 08:44 AM   #1 (permalink)
SteveO's Avatar
Send a message via Yahoo to SteveO
Harbor Freight Portable Air Compressor Review
My dad surprised me with a Harbor Freight Portable Air Compressor. We were chatting about air compressors and he started planning for our upcoming Moab trip. So, he purchased this online and had it sent to me.
clicky to see the site and specs
Last night I did a tire rotation on my BFG/AT 35x12.5x15 tires.
After the tire rotation, I aired down the front left tire to 15psi to test this thing out. The air compressor has a built in gauge to tell you how much air is in the tire, and the air nozzle screws onto the valve stem to ensure no air loss.
Before the test, I used my high-dollar low-pressure air gauge to measure and ensure that my starting point pressure was set at 15psi.
Now to set the stage, my elevation is about 6500ft and my tires, as noted above, are 35x12.5x15 BFG/AT that are in good shape, as well the weight of the vehicle was on the tire during this test.
From 15psi to 28psi I counted 6 minutes and 30 seconds. I stopped at 28psi because the built-in gauge was reading 30 psi. When I took the air nozzle off and measured the air pressure with a high-dollar low-pressure air gauge, I measured 28psi. So, in reality, it took 6 1/2 minutes for go from 15psi to 28psi, only 13psi difference. So, at this elevation, about 6500ft, the compressor pumps approximately 1 pound of air every 30 seconds.
Given this ratio and elevation, if I was to attempt to air up from trail pressure, about 10psi to street pressure, about 30psi, the Harbor Freight compressor would spend approximately 10 minutes per tire. For all 4 tires, that is about 40 minutes, given the compressor doesn't shut down due to thermal protection.
In contrast, the Power Tank I carry, does each tire in about 1 minute or less. Actually, I need to measure it for more accurate results. According to the PowerTank site and their numbers, its 38 seconds.
The Harbor Freight air compressor is a great backup to the Power Tank or any CO2 tank, and if necessary, it will get the job done, but not very quickly. However, quickly is a relative term. What is quick for me, may not be quick enough for somebody else. So, in my own personal opinion, when the viable options are weighed out, I would prefer a CO2 tank over the Air compressor. I will still hard mount the Air Compressor and plumb it into my system so it can be a back up to the onboard ARB compressor. Redundancy is a good thing when you are out in the bush with nothing but your own resources.
SteveO is offline
Sponsored Links
To remove this ad, register today!
Old 05-12-2008, 12:01 PM   #2 (permalink)
Red_Chili's Avatar
Interesting, I wonder how that compares with the MV-50 compressors I run?
Seems like it takes a lot less time to inflate from 11psi to 30, but then, I run two in tandem, hardmounted, with the bumper as a tank. I too believe in redundancy! The things I started not liking about CO2 were:
1) I ran out right when I needed to fill one more tire, or two more.
2) Not that convenient to fill. Or it seemed that way. Nothing in Moab, and the place near me usually has tanks to swap, but not always.
3) When sleeping in the back of the truck, it was one more thing in my way. And more weight.
4) I needed a compressor anyway for the ARBs. I would not want to plumb CO2 for them, though you could. If you ran out, you would have neither air NOR lockers. Not good.
The drawback to the electric compressors are:
1) requires a couple 30A breakers. They draw a lot. I have a high cap. alternator now, and two yellow top batts, so not a big deal.
2) Both relays in the compressors died. No matter, I am controlling them with external relays anyway, so these were redundant. I simply removed them and soldered the wire in its place. Replacement 30A automotive relays are as common as Checkers/Kragen or Radio Shack.
__________________
-Bill
Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here.
Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD!
Bio Page
Red_Chili is offline
Old 11-12-2008, 07:07 PM   #3 (permalink)
I have the same compressor. I tried using it to fill up a portable air tank. When it got to 90 psi the thing broke. The motor still worked but the piston inside was toast. Its made of plastic. I suppose if its used for tires only it would be fine.
__________________
nothin says buck, like a toyota truck
85TurboRunner is offline
Old 11-13-2008, 12:28 PM   #4 (permalink)
Red_Chili's Avatar
Mine are going on three years, still working, filling the bumper/air tank.
Just luck of the draw.
__________________
-Bill
Bio Page
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
looking to buy a portable air compressor weakyota91 General Vehicle Related Topics (Non Year Related) 0 05-08-2007 10:25 AM
Portable Electric Air Compressor mastacox Offroad Tech 9 07-13-2006 12:25 PM
How should I mount my portable air compressor? yoda92 95.5-2004 Tacomas & 96-2002 4Runners 7 12-08-2005 09:30 AM
Harbor Freight? rondo221 95.5-2004 Tacomas & 96-2002 4Runners 20 07-09-2004 03:29 AM
Best 12V Portable Air Compressor? BT17R 95.5-2004 Tacomas & 96-2002 4Runners 8 03-25-2003 02:44 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
