YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Product-Gear Reviews > Product Reviews
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-26-2008, 01:58 AM   #1 (permalink)
Ryan's Avatar
Energy Suspension
I have used www.energysuspension.com bushings in several vehicles I have and I am very impressed with them. I am most happy with the fitment and engineering of the new Polygraphite control arm bushings for 4Runners. I have just purchased a set of upper and lower Polygraphite bushings for my 86 4Runner and I am very impressed with the fitment and design. I also use there Polyurethane bushings for the sway bar & end links, shocks, etc. I am very satisfied with the way they are made and how long they have lasted all my other vehicles, especially the Polygraphite ones. Energy is a great solution to replacing any bushing because there are IMO made better than OEM, a lot cheaper than any OEM or OEM style bushings, and I am sure the Polygraphite bushings are going to last at least 3 times longer than any OEM rubber bushing. I am very satisfied with these and I am a huge critic of most aftermarket parts. Check out there website to see what they have for your vehicle. www.energysuspension.com/
__________________
1986 4Runner SR5, Stock 22RE w/5speed, Rear Detroit Locker, Front LSD, 4:88 Gears, 4" Lift, New Mickey Thompson Baja MTZ 33X12.50X15 Tires on the way.
Mtn Bike For Sale:
http://www.yotatech.com/f110/cannond.../#post50888473
Ryan is offline
Sponsored Links
To remove this ad, register today!
Old 08-26-2008, 06:00 AM   #2 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
I use a lot of ES stuff on my personal Toyotas and have installed a lot of ES stuff on customer's Toyotas. Great products and available on my website for some of the more popular applications.
waskillywabbit is offline
Old 08-26-2008, 06:28 AM   #3 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
amazing quality, that's all i have to say. i am about to order an entire bushing set for my rig.
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 09-06-2008, 04:17 PM   #4 (permalink)
Ryan's Avatar
I agree guys. I just started distributing Energy Products and bought a complete set of every part available for all my Toyotas and Hondas. I am very happy with the Polygraphite bushings I am installing right now and the other Polyurethane bushings are pretty nice too.
__________________
Mtn Bike For Sale:
Ryan is offline
Old 10-20-2008, 01:01 PM   #5 (permalink)
I have a set of these. I took the front control arms off to install bj spacers and clean up rust. How do the control arm bushings go in? in the upper control arm, on a 92 reg cab 4x4, there is a cross piece between the 2 eyes of the control arm. this cross piece is what bolts to the truck. Anyway, the cross piece does not appear to come out. Do you just heat and dig the old rubber bushing (mine is quite worn, but doesn't appear to sag while not under load, under load who knows), grease up the sleeve and hammer the poly bushing in? This is what I am thinking about trying, but I am a little nervous about digging out the old bushing and ruining the whole thing.
Also if anyone has done an install of the bushings on the front end, and made a thread on it I would love a link. The pieces are in bags in the box broken up in to areas of the truck, but a detailed map of where exactly each piece goes would be awesome too.
I think I know where everything goes, but I dont want to mess anything up.
__________________
Tom H
Mt Vernon, MO
chief designer of the oxy-moron (head moron reporting)
http://www.yotatech.com/f151/project-oxy-moron-151018/
trbizwiz is offline
Old 10-22-2008, 09:20 PM   #6 (permalink)
King of Crown Town's Avatar
I bet if you call Energy Suspension. One of their mechanics would be more than happy to help.
__________________
1993 V6 4WD Toyota 4Runner 203,000 Miles 50K on new gaskets
Corona, CA
www.myspace.com/395rider
www.youtube.com/kingofcrowntown
King of Crown Town is offline
Old 10-23-2008, 07:28 AM   #7 (permalink)
I got my new harbor freight shop press put together last night. The bushings pushed right out. It was actually pretty easy. As far as I am concerned this is the best $100 tool I have bought for working on my yota. It will be great for pressing out the leaf spring bolts and bushings too, and If IO decide to rebuild my thirds I am all set.
If anyone else decides to replace their control arm bushings with poly, get ahold of a shop press. Put the control arm in the press with the rear side up, and press down on the bolt. the front bushing will pop right out, and the rear bushing will stay in but just stretch. then the bolt and shaft will slide down and you can lift it out. flip the control arm over so the rear eye is facing down, place a socket large enough to cover the bushing but small enough to fit inside the sleeve, on the bushing. Place the bolt and shaft back through the front control arm eye and then drop it down into the socket on the inside of the rear CA eye. place it all in the press and press the shaft down. IF the bushing doesn't pop right out (mine dint, it stretched about a foot I think) put a little heat on it and it will pop right out. Then burn or wire wheel out the sleeves to clean them up, and they are ready for bushing install.
__________________
Tom H
Mt Vernon, MO
trbizwiz is offline
Old 11-05-2008, 01:34 AM   #8 (permalink)
Ryan's Avatar
That is pretty much what I did. I did have to burn out the old rubber on a few since they were coming off an 86 4Runner LOL.
__________________
Mtn Bike For Sale:
Ryan is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Energy suspension bushings One_96TR4 95.5-2004 Tacomas & 96-2002 4Runners 5 11-20-2007 04:34 PM
Energy Suspension Bushings pinkfloyd73 Axles/Suspensions/Tires/Wheels 0 06-29-2007 03:33 AM
FS: Energy Suspension Bushings Noel Misc Stuff (Vehicle Related) 10 02-27-2006 08:08 AM
Energy Suspension smr4runner 95.5-2004 Tacomas & 96-2002 4Runners 5 04-29-2003 10:13 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
