Dual Exhaust - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Product-Gear Reviews > Product Reviews
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-04-2005, 03:17 PM   #1 (permalink)
Dual Exhaust
Im wanting dual exhaust for my 02 V6 Taco, now im wanting headers and exhaust.
Peformance wise what should i go with?
Im looking at JBA Headers, should i even bother with JBA..
I can't find Borla Dual Exhaust kits of my truck so how would i go about running dual exhaust ?
If this was your truck, how would you go about doing this........ or would you even go with dual, i like the look of dual too.. Tell, me What would be best Performance Wise.....
__________________
2002 Toyota Tacoma Prerunner Ext.Cab
Kenwood Headunit, 2 10'' Audiobahn Flame Compression Subs 2000 watt RMS peak power with a Audiobahn 2000 watt amp..... :-D power !
Future upgrades:
Borla Exhaust
3'' suspension lift
bamboo89 is offline
Old 12-04-2005, 03:36 PM   #2 (permalink)
marko3xl3's Avatar
Send a message via AIM to marko3xl3
Performance wise, all exhausts are the same. They might add a little un-important power, but exhaust mods are mostly "sound" mods. Headers can increase hp and for the 3.4L there is not really a difference between one header or another, there is only quality. See: http://www.gadgetonline.com/Exhaust.htm.
I would also look into if it's even possible to put a "real" dual exhaust system in your truck. I know that in 3rd generation 4Runners, the spare tire gets in the way, so it's either get rid of the spare or just have a dummy pipe. Tacomas might be different though.
__________________
:Marko:
Supercharged 98 4Runner SR5 4x4 3.4L
4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator
XM Satellite Radio (Roady 2)
:: Autometer Boost Gauge :: Color Keyed Spoiler
TOYOTA|moving forward
marko3xl3 is offline
Old 12-04-2005, 03:39 PM   #3 (permalink)
bob200587's Avatar
I always liked the pipes to come out at the rear corners....like this: /\ kinda....i don't know anything about whats good for so new of a truck, Borla is always good, but it is expenisve.
__________________
87 4runner 4x4 SR5 22RE
ARB Bull Bar,
31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header
AISIN Manual Hubs, Marlin Crawler Sliders
190XXX miles
bob200587 is offline
Old 12-04-2005, 04:00 PM   #4 (permalink)
Very true, Borla is good but Very expensive,
Now if i bought Borla Exhaust, or if i wanted Borla and wanted to run it dual, what would i ahve to do?
__________________
Future upgrades:
Borla Exhaust
3'' suspension lift
bamboo89 is offline
Old 12-04-2005, 05:24 PM   #5 (permalink)
HUTCHSTACO's Avatar
i have the same truck and did magnaflow with a y so it comes out on the driver side like it does on the passanger, also did a high flow cat to get a little deeper sound. i had to get a fabtech bed mount because i could not have a tire under there and dual pipes. it looks good though.
HUTCHSTACO is offline
Old 12-04-2005, 05:34 PM   #6 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Marko mentioned your first step above... See if you can even physically fit dual exhausts under the truck.
Past that... decide what "dual" means to you:
  1. Single cat, single muffler, one real/one fake tail pipe
  2. Single cat, single muffler, twin tails
  3. Single cat, twin mufflers, twin tails
  4. Twin cats, twin mufflers, twin tails
If you're gonna run twin everything, you could have an issue with how the O2 sensors (or A/FR & O2 sensor) work. You will have to wire things up on just one side, but you ever got into a spot where the opposite bank was running rich/lean, the ECU would never know about it.
Option #3 (Single cat, twin mufflers, twin tails) will be the easiest in terms of dealing with the ECU and still give you "real" twin tails.
Don't let an exhaust shop talk you into running larger pipe. The 3.4L wants to see some backpressure and the stock pipe size of 2.25" is designed to provide sufficent pressure given that BOTH banks are feeding it. If you run pure dual, then you'll probably want to REDUCE the pipe size to 2".
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 12-04-2005, 05:42 PM   #7 (permalink)
HUTCHSTACO's Avatar
ya, i dont have true dual, im #2 on marks list-
Old 12-04-2005, 06:57 PM   #8 (permalink)
tc
tc's Avatar
First - do you have a CA model with dual cats? If so, then you're all set for a true dual system, which will show a significant performance increase. IMHO, as long as you only have one cat, you may as well only have one exhaust. You could do a true double system with a crossover pipe after the cats where you mount the O2 sensor.
I totally disagree with Marko. There is a HUGE difference in header design, not just quality. The best headers have the lengths very carefully matched to optimize the scavenging effect. Different mfgs will tune them to different points empasizing low or high end power. The cheapest ones just use whatever length happens to work.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 12-05-2005, 07:54 AM   #9 (permalink)
CA model? I have the single side exit exhaust, I want to run the Single cat, twin mufflers, twin tails, or the single cat, single muffler and twin tails,
__________________
Future upgrades:
Borla Exhaust
3'' suspension lift
bamboo89 is offline
Old 12-05-2005, 10:47 AM   #10 (permalink)
Sponsoring Member
midiwall's Avatar
CA model?
You'll need to look under the truck... Count the number of "things" in the exhaust piping from the "Y" pipe back. Do you have two (cat, muffler) or three (cat, cat, muffler)?
btw.. headers on a N/A engine won't do anything for you except drain your wallet. It's a waste of time & money. Wait until you move to a S/C or turbo, HEN put on headers.
__________________
~ Mark
midiwall is offline
Old 12-05-2005, 11:12 AM   #11 (permalink)
rimpainter.com's Avatar
Quote:
Roger that.
rimpainter.com is offline
Old 12-05-2005, 11:13 AM   #12 (permalink)
Its just one cat. yeah just one cat.
__________________
Future upgrades:
Borla Exhaust
3'' suspension lift
bamboo89 is offline
Old 12-05-2005, 11:26 AM   #13 (permalink)
Sponsoring Member
midiwall's Avatar
Good, that'll keep things simpler.
Okay, so the first question you/we need to deal with is "do you still want to run headers"? If you're looking at moving to a turbo or S/C in the next 4-6 months, then it makes sense, but anything more than that, then you're wasting a LOT of money ($1000 or more by the time it's done).
Second question is "one muffler or two"? Two mufflers MIGHT (your bottle neck will still be the cat) free-up some exhaust flow, but again, without more air coming in up front (turbo or S/C) then there's no reason to care. Also, you may not have the room under the truck to stuff a 2nd muffler. (the reason the exhaust runs down the passenger side now is 'cause there's a gas tank on the driver's side).
So the third question, (once we talk you into just one muffler) will be the twin tails. Again, "do you have room"? There's a bit easier of a path from the muffler to the back end (or side, or opposite side) but there's still some stuff in the way. If you're looking for twin tails out the back, there's a spare tire blocking the easy path.
Thoughts and ponderings?
__________________
~ Mark
midiwall is offline
Old 12-05-2005, 09:28 PM   #14 (permalink)
Twin Tails, one muffler, :-D i like the look of twin
__________________
Future upgrades:
Borla Exhaust
3'' suspension lift
bamboo89 is offline
Old 12-05-2005, 10:35 PM   #15 (permalink)
HUTCHSTACO's Avatar
i love my twin tails, i had two cats, replaced them with one highflow magnaflow one size up from my pipe size. im happy w/ it.
Old 12-06-2005, 12:52 AM   #16 (permalink)
Sponsoring Member
midiwall's Avatar
Okay, then your next step is to make sure that you can route twin tails. Jeff (HutchsTaco) has done it... I think he'll be your source for routing.
Have fun!
(oh, and did we/I talk you out of headers? )
__________________
~ Mark
midiwall is offline
Old 03-27-2006, 08:37 AM   #17 (permalink)
97Limited's Avatar
Hey bamboo89;
If you need an idea on an option for dual Exhaust?? Take a look at my current set-up!!
I think you have a little more room for the tail pipes on your Taco then my Runner so I think you can get away with leaving your spare in!!
I'm running single cat, Dual outlet muffler, two tail pipes!!
Soon i'll be making it "true" dual exhaust with headers, 2 cats, 2 mufflers, 2 tail pipes!!
Good Luck and keep us posted!!
__________________
1997 4Runner Limited;
3.4L 4WD; Rear E-Locker; OEM/Sonoran Steel 3.5" Lift; ARB Tacoma BullBar w/ 525 PIAA Dual-Beam Lights; Alpine/JL Audio; CompuStar; TRD Headers w/ Magnaflow custom dual exhaust; 305/70 XTerrains on Blacked-out A/R wheels; Tundra Brakes; 4" Deckplate mod w/ TRD filter; ISR mod; Yellow Top Optima w/ custom tie down; Custom grille inserts; JDM Black headlights w/ 6000k HID's; Extended diff breathers
PICS> ::97 4Runner Site::
97Limited is offline
Tags
2003, 2009, adding, bar, bull, dual, exhaust, exhausts, kit, prerunner, side, single, steps, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Dual exhaust/muffler ???'s emptypockets 95.5-2004 Tacomas & 96-2002 4Runners 22 12-29-2006 02:37 PM
What's the best Tundra Dual Exhaust ???? Brtn540 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 1 08-19-2005 05:51 AM
how to: dual exhaust? gtfourdreams 95.5-2004 Tacomas & 96-2002 4Runners 16 12-04-2004 11:40 AM
Dual Exhaust 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 17 07-16-2003 08:12 AM
Dual Exhaust Lurch 95.5-2004 Tacomas & 96-2002 4Runners 25 12-16-2002 06:14 AM
2009 InternetBrands, Inc.
