Cool It - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Product-Gear Reviews > Product Reviews
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-17-2005, 04:40 PM   #1 (permalink)
fireman1525's Avatar
Send a message via AIM to fireman1525
Thumbs up Cool It
Just installed my cool it wrap by Thermo TEch. I saw it advertised to reduce engine temps dramatically. You wrap it onto your header or manifold and strap it down with metal straps. it is like fiberglass and graphite and works great. especially since i just recently put my FIPK in. Cooler engine compartment temps means cooler air, which = more horses and better MPG. I can definately tell a difference in both. Got it from alamomotorsports.com
__________________
I gotta fart but i don't know which way to lean!
'94 Yota 4Cyl. 4WD, Rock Crawler 15x10's, 32x12.50 Dunlop Aurora MT's, K&N FIPK, Headlight conversion, Cool It exhaust wrap, 2" Pro Comp Susp. lift...
fireman1525 is offline
Old 05-18-2005, 03:05 PM   #2 (permalink)
eventually tho the heat build up inside your heades caused by that wrap will cause them to get too hot and crack or warp.
__________________
91 toyota pick up regular cab, 22re with unifilter, flowmaster exhaust, sway away torsion bars, custom made upper arms, 31 BFG all terrains (soon to be 33 bajas), bilstein 5150's all around, hella 500's up front and a shiny diamond plate tool box for all my junk
desert whomper is offline
Old 05-19-2005, 08:55 AM   #3 (permalink)
Probably
Your Are Probably Right, But The Mechanic I Talked To Said That If I Had Aluminum Headers It Might Eventually Cause Problems, But B/c I Have A Cast Manifold Right Now, It Shouldn't Cause Any Harm Due To The Strength Of The Cast. But If It Cracks It Will Give Me A Reason To Order Headers From Lcengineering!
__________________
Old 05-20-2005, 01:33 AM   #4 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
cast cracks easy keep it out of water and you might be ok
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
this is cool Lotus1 Off Topic Talk 1 11-01-2005 08:27 PM
Had a cool yet no so cool dream last night Yoter Off Topic Talk 6 01-12-2005 04:20 PM
A/C not cool... rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 2 05-26-2004 08:43 PM
This is too cool... Firefyter-Emt Off Topic Talk 4 07-08-2003 08:43 AM
2009 InternetBrands, Inc.
