Aussie locker review - Page 7 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Product-Gear Reviews > Product Reviews
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-01-2009, 04:37 PM   #151 (permalink)
Hey so quick question for you Aussie owners: at what throttle position will the locker engage??? I'm curious because I DD my 4runner around town and on the interstate. I don't want the thing locking on me during a 70 miles per hour corner.
Jadri is offline
Old 07-02-2009, 10:35 AM   #152 (permalink)
ajoebob's Avatar
I've had mine in or around a year now and i cant even know its there when i drive it on the road.when it was new it would grab hard on a 90* turn but know that its broke in i have to be throttling thou it hard to keep it locked. but it still works great off-road like its supposed to. i like mine and would do it agen but also mine is 98* off-road only but the locker dose good on the pavement when i get it on there.
__________________
'82 toyota pickup 5" lift, weber 36deg carb, 32x11.5 sx super swompers,rear aussie locker,5.29 gears, cb, and 261*c cam
ajoebob is offline
Old 07-10-2009, 02:12 AM   #153 (permalink)
Matt16's Avatar
Quote:
Not an issue. The locker is invisible above 20mph, you really have to provoke it in to jerking/ locking at speeds more than 10mph.
The locker still unlocks at full throttle in second gear going around a 90 turn at 10mph in my truck.
Ideally, you want to keep just enough tension in the driveline going around corners. Its pretty easy to figure out once you drive it, but hard to explain on paper. One easy way to accomplish this is go around corners in a higher gear than usual but give it more throttle.
Unlike some people on the board here, my truck drives 40% city, 40% highways, 18% dirt roads, and 2% technical 4wd trails. I have not found the locker to be as invasive as some people suggest it may be. Its not something that passengers are usually aware of, even when driving on ice or snow.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 07-10-2009, 02:45 AM   #154 (permalink)
CRafferty's Avatar
In what type of 4R are you doing 70 miles per hour cornering maneuvering?
Did you use that platform for this?
Sorry for the off topic jargon.
__________________
Lilly:
1992 4Runner 4x4 SR5
3.0L V6 32" BFGoodrich A-T T/As Pro Comp ES3000s
4Crawler BJ Spacers and Coil Spacers. ISR Mod.
Soon: 4.88's, LC's, Skids.
Her page: http://www.yotatech.com/f78/collin-s.../#post51096834
Ike:
1947 Willy's Jeep
Ford 134L I4
1ton 3" lift springs on 33x6.5 Mud Terrains
Quote:
Originally Posted by Matt16 View Post
Toyota makes the Hilux. Complementary base-pairing makes a (double) helix.
Quote:
Originally Posted by Jimmeh View Post
As long as people listen to music, then at least they are human, right?
CRafferty is online now
Old 07-13-2009, 11:53 PM   #155 (permalink)
^^^ I 580 and 680 going towards the bay.. Its just how traffic moves on that road!
Jadri is offline
Old 08-15-2009, 05:00 PM   #156 (permalink)
mrddk92's Avatar
Im looking at regearing in a few months to 4.88 and might stick a locker in the rear at the same time. ZUK recommended a Detroit Soft locker for the rear and an Aussie for the front(if i really had to have one). ill have to ask about the Aussie in the rear.....anyone have any exp with the detroit or a link for more info? i searched but didnt find any good write ups like this one.
__________________
92 x-cab dlx 3.0 5spd 265k stock suspension 32x11.5x15 bfg all terrains plumbing isr mod, weasy cams, lce headers, 2.25 cat-back exhaust with high flow cat and cheap turbo muffler (sounds good tho)
mrddk92 is offline
Old 08-20-2009, 10:09 PM   #157 (permalink)
Matt16's Avatar
You can't yet get a Aussie locker for the factory 4.88 diff or any V6 diff for that matter.
__________________
Toyota FAQ link
Matt16 is offline
Old 10-01-2009, 09:29 PM   #158 (permalink)
Stuwy123's Avatar
Aussie just came out with a "V6 locker", but the pre-95 V6 diffs are 27 spline. Just like the 4 cyl.
I don't know which one to get for my earlier 90's V6 4.88 rear diff.
Stuwy123 is offline
Old 10-02-2009, 06:28 AM   #159 (permalink)
Dingman's Avatar
Just my $0.02 on an Aussie in the front.
No complaints so far. I'm a fairly mild wheeler normally but I do get into some bad stuff occasionally, and the Aussie has never failed (I've been stuck but the Aussie stayed locked).
It is rather loud when it unlocks (you can but I that's ok. And it does take quite a bit of pressure to unlock.
Obviously, I never drive it on the road in 4WD.
Mine was set up as a complete third by Zuk for me and I installed.
Dingman is offline
Old 10-03-2009, 06:44 PM   #160 (permalink)
Matt16's Avatar
You stole my thunder, and beat me to the punch.
Here's the locker you want. I wonder if its "in stock"?
http://www.offroadlockers.com/item.p...0/120009/.html
__________________
Toyota FAQ link
Matt16 is offline
Old 11-08-2009, 05:29 PM   #161 (permalink)
I just sent them an email and they say that they are in stock. Based on this review I am going to purchase one. I will post my review when it is in. Thank you Yotatech I Have been a long time reader but this is my first post.
throttle-junkie is offline
Tags
03, aussie, buy, engage, gear, locker, lockers, lockright, noise, oil, reducing, review, reviews, works, xterra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Aussie Locker phildelfino Newbie Tech Section 12 12-21-2007 09:17 AM
aussie locker bucketofbolts 86-95 Trucks & 4Runners 7 05-25-2007 11:13 PM
Aussie locker 4runnin2 95.5-2004 Tacomas & 96-2002 4Runners 9 01-23-2007 10:09 AM
Looking at a Aussie locker few ??? Lunnzz 86-95 Trucks & 4Runners 24 08-06-2006 11:04 AM
Aussie Locker Jonathan Offroad Tech 35 10-05-2003 10:20 PM
2009 InternetBrands, Inc.
